メインコンテンツにスキップ
Repair Guide for the LG Net10
必要な工具と部品
  1. Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 手順 1、 2の画像 1 Repair Guide for the LG Net10, Complete disassembling of the phone to get to the motherboard: 手順 1、 2の画像 2
    • Frontal view and rear view of the LG Net10 prior to disassembling.
  2. Repair Guide for the LG Net10: 手順 2、 2の画像 1 Repair Guide for the LG Net10: 手順 2、 2の画像 2
    • Remove battery back cover by applying pressure along the groove. The LG logo should be up right. Apply the pressure downwards to remove the cover.
  3. Repair Guide for the LG Net10: 手順 3、 2の画像 1 Repair Guide for the LG Net10: 手順 3、 2の画像 2
    • Remove the battery from the top of the battery.
  4. Repair Guide for the LG Net10: 手順 4、 1の画像 1
    • Remove the SIM card, by pushing down on the top of the SIM card and sliding it out from under the metal band.
  5. Repair Guide for the LG Net10: 手順 5、 2の画像 1 Repair Guide for the LG Net10: 手順 5、 2の画像 2
    • Remove all four screws from the back of the phone by using a small Phillips head screwdriver and turning it counterclockwise.
    • The screws are 0.5 centimeters.
  6. Repair Guide for the LG Net10: 手順 6、 3の画像 1 Repair Guide for the LG Net10: 手順 6、 3の画像 2 Repair Guide for the LG Net10: 手順 6、 3の画像 3
    • Use a wedge, or flat edged tool to separate the phone. Make sure to circle around the entire phone, especially the corners to pull it apart. This can be difficult. This may take several tries, so make sure to be persistent.
  7. Repair Guide for the LG Net10: 手順 7、 1の画像 1
    • Separate and remove the two hard covers and the keypad.
  8. Repair Guide for the LG Net10: 手順 8、 2の画像 1 Repair Guide for the LG Net10: 手順 8、 2の画像 2
    • Then remove the motherboard from the hard back of the phone.
  9. Repair Guide for the LG Net10: 手順 9、 1の画像 1
    • Once the phone is completely dissembled, you can replace the screen if it is cracked. You can also replace the keypad if the buttons do not work or if there are other issues with the keypad. Another common desire people have is to unlock the phone. In order to do this, you must replace the SIM card, which is explained in the steps above.
終わりに
作成者
4人の作成者と共同で作成されました。
Gina
メンバー登録日: 04/15/13
125 ポイント
2のガイドは作成済み
チーム
SUNY Cortland, Team 1-1, Getto Spring 2013 SUNY Cortland, Team 1-1, Getto Spring 2013人のメンバー
SUNYCORT-GETTO-S13S1G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 1,199
