はじめに
Usa esta guía para remplazar la batería CR2032 tipo moneda de tu PlayStation 3 Slim
必要な工具と部品
Dale la vuelta a tu PS3 y colócala con la parte trasera hacia arriba.
Con cuidado, quita la pegatina de la garantía, así podrás acceder al tornillo que se encuentra escondido debajo de ella.
Aprieta el mecanismo que bloquea el conector del enchufe AC y tira de él hacia arriba para desconectar la fuente de alimentación.
Mientras sostienes el retenedor de plástico contra la placa, usa la punta de un spudger para sacar la batería PRAM de su carcasa
Para ensamblar tu dispositivo, siga estas instrucciones en el orden reverso
24 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
9 件のコメント
ATTENTION: This guide is not valid for PS3 slim CECH-3004B!
from the number 11 you notice that your ps3 is different.
The CECH-3004B version does not give direct access to the 2032 battery.
You must also disassemble the motherboard from the grid (and all the pieces that obstruct this operation)
It is possible but it is more difficult
I found this to be the case too. Did you end up replacing the battery? If so, how did you do it?
Same for CECH-2501A, I got the blu-ray drive out and was greeted by a battery covered by the metal shielding. Have to go deeper...
It is kind of hard to tell by the photo alone: The plus (flat) side of the battery must face up when you insert it.
kuhnbn hob - 返信
hey i need serious help i opened my super slim to replace the battery and could not figure how to get it out thought off lifting the socket might allow me to replace the battey much to my horror now socket is torn from the motherborad my console is stuck in black screen and a day before i tried to update from safe mode still a black screen now if i turn on the console i know its waiting for to confirm update iniatlization can i update the console without cmos battery or shomhow cancel it and be able to boot into recovery again
