メインコンテンツにスキップ
この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください
Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546
必要な工具と部品
ビデオの概要
Légende de la vidéo
  1. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546, Bandes adhésives: 手順 1、 3の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546, Bandes adhésives: 手順 1、 3の画像 2 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546, Bandes adhésives: 手順 1、 3の画像 3
    • Avant de commencer à placer des bandes, enlevez tout le vieil adhésif. Utilisez un spudger pour écorcher un bord, puis pelez avec vos doigts.
    • Retirez toutes les bandes adhésives restantes sur l´encadrement de l´iMac et du verre de l'écran.
    I've done this on several iMacs now, but today I noticed another layer of thin black plastic stuck to the back of the display.
    It was really tough to remove and left a lot of clear, sticky goop under it.
    It's really thin, but it was strong enough to hold the screen in place by itself - I reconnected the display cables and tested before pulling the backing off the new adhesive strips - and it stuck together!
    I had to pry it apart again and it actually ripped my new glue strips in 2 or 3 places. I was able to still use them, but it did not go as smoothly as other iMacs I've upgraded. Everything was fine in the end, but I left some blue painters tape on the top of the screen overnight so the glue strips will set up without the screen falling off - just to be on the safe side.
    Does anyone know if this last layer of black plastic on the screen should be removed or left in place when replacing the glue strips?
    Daniel Cassel - 返信
    That Black layer of plastic should not be removed. I found that on some segments, upon peeling back old adhesive remnants, the thin black plastic layer would also begin to peel off. STOP and cut off what has been removed, separate the black plastic strip from the adhesive remnant you are peeling off. The continue removing remnants.
    Macrepair SF - 返信
    Are you sure that you’re not supposed to pull the black backing all the way off? I removed all the black strips before getting to this step.
    Tom Tompkins - 返信
    IMHO: The rubbing alcohol is clutch for this step. There’s plenty of residue after pulling up the old adhesive and the 99% Isopropyl Alcohol really took the tacky remnants off.
    Ben Hannam - 返信
    To add on to the rubbing alcohol thing for removing residue, the alcohol doesn’t actually dissolve the adhesive residue, but softens it and makes it easier to get up. But you still have to actually remove it. I found that once you peel up the big pieces of adhesive, you’re still gonna have a some sticky residue. Here’s what worked for me:
    1) You want to go section by section, using a clean piece of non-linty cloth wet with alcohol to get the glue residue nice and wet. As it says in the instructions, don’t wipe back and forth, but wipe the residue along in one direction instead of just spreading it around.
    2) The plastic spudger that came with your repair kit (or the end of a credit card or something plastic that won’t cause damage) can be used as a little trowel to push the adhesive along and gather it up into a little booger-like hunk of goo.
    3) At that point, you can wipe it off with a clean, dry piece of cloth. Why dry? Because it won’t really stick to the alcohol-soaked one but will stick to a dry cloth.
    Damian Chadwick - 返信
    It still took me a solid half-hour easily to go along all the edges and get them as clean as possible. I had to go over some sections a few times. This might have been overkill, but I really really didn’t want to go through all this and then find that the new adhesive strips weren’t holding because there was old gunk I hadn’t removed.
    The careful removal of the adhesive is very, very important. Take that from a guy who didn’t carefully remove the adhesive and was awakened in the middle of the night by the screen coming off of the iMac and crashing to the floor. That was a bad night.
    Gary Bandy - 返信
  2. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 2、 3の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 2、 3の画像 2 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 2、 3の画像 3
    • Commencez avec la bande 13, qui est située sur la partie verticale de droite. Avant de décoller une protection de l'adhésif, alignez-le contre le cadre de l'iMac pour avoir une idée de l'endroit où il va.
    • Décollez le petit morceau de protection à l'arrière de la bande.
  3. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 3、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 3、 2の画像 2
    • Insérez la pointe d'un spudger dans le trou au sommet de la bande, du côté qui a encore sa protection .
  4. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 4、 3の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 4、 3の画像 2 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 4、 3の画像 3
    • Tout en maintenant le spudger percé dans le trou de la bande adhésive, poussez la pointe du spudger dans le trou correspondant sur l´encadrement de l'iMac.
    • En utilisant le trou et le spudger pour ancrer la position de la bande adhésive, alignez la bande contre le bord droit, tirez doucement vers le bas contre le spudger afin de vous assurer que la bande est tendue, et collez-la sur l´encadrement.
  5. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 5、 3の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 5、 3の画像 2 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 5、 3の画像 3
    • Une fois que vous êtes satisfait du parfait alignement de la moitié supérieure de la bande adhésive, décollez le morceau plus long de la protection à l'arrière de la bande.
    • Si la moitié supérieure n'est pas alignée correctement, vous pouvez soigneusement la décoller puis la recoller avant de détacher la bande de protection inférieure. Veillez à utiliser la pointe du spudger pour ancrer la partie supérieure.
  6. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 6、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 6、 2の画像 2
    • Alignez la partie inférieure de la bande avec le bord droit du cadre et collez-la vers le bas.
  7. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 7、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 7、 2の画像 2
    • Lissez la bande 13 avec votre doigt. Assurez vous qu'elle est parfaitement alignée avec le côté droit de l´encadrement et qu'elle repose à plat.
    • Ne décollez pas encore la protection frontale de l'adhésif.
  8. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 8、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 8、 2の画像 2
    • Travaillez tout autour de l'iMac, en ajoutant trois autres bandes adhésives de la même manière.
    • Travaillez dans le sens antihonaire à partir de la bande 13, placez la bande 12 en haut à droite, la bande 11 en haut à gauche, et la bande 16 sur le côté gauche.
    • Ces trois bandes ont un trou à chaque extrémité, utilisez toujours le trou le plus petit pour l'alignement afin de le positionner de la manière la plus précise.
    • Sur l'iMac Intel 27 " écran réticulaire 5K, les partis bleus de la bande 12 ne s´aligneront pas aussi bien avec l'antenne du haut qu´un modèle normal. Ceci est parfaitement acceptable et n´affectera pas les performances ni des bandes ni de l'antenne.
    Number 11 is WAY too long and had to be cut. Not good.
    Brian Peixinho - 返信
  9. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 9、 1の画像 1
    • Les bandes 14 et 15 vont sur l´encadrement de l'écran.
    • Retirez la protection blanche du verso de la bande 14.
    Using iFixIt’s adhesive strips, i cannot strip off the white backing. Pulling on the tab pulls the wrong backing off, the black backing. I can:t figure a way to do this correctly!
    Charles Lindauer - 返信
    Same with mine, but carefully using a razor blade to separate the white side from the adhesive, leaving the clear side attached, then remove the white side and place accordingly.
    Phill -
    The video shows the correct method - attach these strips to the back of the screen rather than the iMac itself.
    robinsnaddon - 返信
    The Video can be found at macsales.com support site. Here’s the link:
    https://eshop.macsales.com/installvideos...
    got to 07:48
    Macrepair SF - 返信
    The instructions at this step need to be re-written. The Bullet point that says “Align the strip on the bottom edge of the rear enclosure” is misleading. Strips 14 and 15 are to be Placed on the Bottom Back Edge of the Display! Also note that the way these strips have been manufactured they are a bit funky. They will be placed with the DARK SIDE up, but the film covering the adhesive on these is tough to get properly separated, fortunately I had not cut my nails recently, so I was able to finally get it off after several minutes.
    steve - 返信
    I did this step according to this written guide, and honestly the result was not good, plus it is much harder to put the display back on when the 14 and 15 strip adhesive is attached onto the computer.
    The video (also from ifixit) shows the correct way, putting strip 14 and 15 on the LCD itself. Have done it like this on a previous iMac I had and the results were much more pleasing.
    https://www.youtube.com/watch?v=hSChIAlX...
    robert - 返信
    There is a problem with step 10 of this guide for 27” iMac 5K Display 2019! If you follow step 10 as it is, the iMac microphone port is blocked with adhesive. After following this guide I had to buy an extra set of adhesive strips and reopen my iMac to fix the muffled microphone problem! The correct application of the adhesives in step 10 is described in iMac Intel 21.5" Retina 4K Display (2017) Adhesive Strips Replacement guide iMac Intel 21.5インチ Retina 4K Display (2017) 接着ストリップの交換
    Please do update this guide accordingly!
    Martins Medens - 返信
    LEARN FROM MY MISTAKE: Yes, the video (https://www.youtube.com/watch?v=hSChIAlX...) IS right on this step, but I did something stupid. I based the rest of my screen re-install based on the video, instead of using the rest of this guide (I know, I know, I should have read the whole thing first… I assumed this was the easy part after replacing my hard drive). All that to say, the video doesn’t include any of the helpful painters tape stuff, so I ended up eyeballing the screen with active adhesive, and it ended up slightly misaligned. When I saw the mistake, it was too late to change anything. It’s a very small error, but a noticeable one if you run your finger along the top of the glass, but I am still kicking myself for messing the final step up after an otherwise successful install.
    BARRY RODRIGUEZ - 返信
    Das Microphon befindet sich bei diesem Modell unten rechts über dem Apple Logo (3 Löcher): Nicht überkleben!
    Markus Kaempfer - 返信
  10. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 10、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 10、 2の画像 2
    • Avec la protection frontale toujours en place, alignez la bande 14 avec le bord inférieur droit de l'arrière de l'écran.
    • Le coin en forme de "L" à la fin de de la bande adhésive doit correspondre à l'arrière de l'écran LCD.
    You've really got to pay particular attention to exactly where to stick these - especially the short right-angle part as it doesn't go on the back of the glass as you might expect but actually over part of the edge of the LCD. It's also really difficult to remove and reposition the stickers since they will stretch when pulling them off.
    David - 返信
    Note on the newer iMacs, the microphone is located on the right side of the lower edge. Make sure not to cover this up with tape or your microphone won’t work.
    veenenen - 返信
  11. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 11、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 11、 2の画像 2
    • Lissez la bande adhésive du bout des doigts, commencant par le centre vers l'extérieur pour assurer une bonne étanchéité sans bulles ou rides.
    Isn’t the step of peeling off the bottom sticker missing?
    alessandroteruzzi - 返信
  12. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 12、 1の画像 1
    • Répétez les 3 étapes précédentes pour placer la bande 15 sur le côté gauche du bord inférieur de l'arrière du panneau de l'écran.
    • Les bandes 14 et 15 devraient venir en butée bord à bord au centre de l'écran.
  13. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 13、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 13、 2の画像 2
    • Décollez et retirez la protection des bandes 15 et 14 sur l'écran.
  14. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 14、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 14、 2の画像 2
    • Décollez et enlevez les protections restantes de toutes les bandes autour de l´encadrement.
  15. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 15、 1の画像 1
    • Surtout ne pas abaisser complètement l'écran dans cette étape ; il restent encore deux câbles à attacher. Une fois que vous avez fixé l'écran vers le bas, vous ne serez pas en mesure de le soulever à nouveau sans endommager l'adhésif.
    • Poser le bord inférieur du verre de l'écran contre le haut du joint inférieur. Assurez-vous d'aligner les bords de l'écran avec les bords du boîtier arrière.
  16. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 16、 1の画像 1
    • Tout en soutenant l'écran avec une main, rebranchez les câbles d'affichage et d'alimentation, comme indiqué dans l'étape suivante.
  17. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 17、 3の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 17、 3の画像 2 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 17、 3の画像 3
    • Insérez délicatement le connecteur de l'écran dans son logement sur la carte logique. Assurez-vous de l'emmener droit dans la prise, et insérez-le complètement.
    • Retournez le connecteur de l´écran et verrouillez vers le bas sur son support. .
    • Insérez le connecteur d'alimentation de l'écran dans son logement sur la carte logique.
    Bonjour. Avez-vous des photos comment rebrancher le connecteur mâle - femelle côté écran ? De face ? Par le haut, par le bas ? Pas réussi à remettre. Merci
    Pixelcabane - 返信
    @pixelcabane Ce tutoriel n'est plus à jour. Veuillez consulter à la place https://fr.ifixit.com/Tutoriel/Remplacem... et https://fr.ifixit.com/Tutoriel/Remplacem... pour plus d'infos sur le remplacement de l'écran. Si cela ne vous aide pas, le mieux serait de poser votre question sur notre Forum (https://fr.ifixit.com/R%C3%A9ponses) prévu spécialement à cet effet. Là-bas, tous les membres de la communauté vous aideront à résoudre votre problème.
    Claire Miesch -
  18. Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 18、 2の画像 1 Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546: 手順 18、 2の画像 2
    • Avant de sceller l'écran en place, vous voudrez peut-être tester la mise sous tension de votre iMac pour vous assurer d' avoir tout reconnecté correctement. Faites attention à ne pas toucher quoi que ce soit à l'intérieur pendant que la machine est sous tension.
    • Tout en appuyant l'écran contre son rebord sur le panneau frontal inférieur, abaissez-le en place.
終わりに
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
187 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en fr
55%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
11人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,749 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,732のガイドは作成済み
17 件のコメント
Hello guys!
Could anyone tell what the width of these strips is? I need to buy some double sided strips to do a hard drive upgrade, but I can't order from iFixit :(
Thank you!
Gonzalo Urioste - 返信
Some 3m Extreme Mounting tape works perfect for hdd upgrades on an imac.
http://bit.ly/22snsn1
torch130 -
Hey guys... there's one critical step that's missing here. Before doing Step 18, you have to make sure the iSight camera is in the right place. It's 'floating' inside the computer housing and has to be positioned just right for the glass to close/seal properly with the frame. I followed all of these steps but the glass would not seal around the camera, leaving a 1/8" gap there and distortion on the LCD when powered on. I had to re-order the strips and do the process over again. While doing a 'dry run', I realized the camera was the culprit and was able to hold it in position with a paper clip which allowed for the glass to adhere properly on the 2nd try.
raven13mb - 返信
I'm surprised to see, that you install the tape strips on the unit lying down.
It's a lot easier to attach them with the unit standing upright.
Also, attach ALL the strips to the rear housing, NOT to the LCD.
Attach the tape strips to the housing, mount the display, use som painters (/masking) tape, when you have aligned the display to the edges of the housing, attach the tape to the bottom of the glass and rear housing, making sure the display won't slip out of alignment.
Then, tilt the display towards you and support it with either a hand or your chest, while you remove the tapes protective layer and tilt the display back.
That way, it's still well aligned and it won't shift.
Same goes when removing the display in the first place.
Don't lay it down on the table - use a wedge, to make sure that the housing doesn't tilt while removing the display, and let the wedge stay there unit finished. The display is a lot easier to handle when upright, and you won't put too much pressure on the edges of the glass.
MorbidMylar - 返信
By the way, a minor detail you guys left out;
The tape strips for the 2012 and 2013, are not the same as 2014 Retina model.
The WiFi antenna's are located differently on the right. It's slightly elevated on the Retina, compared to the 2012 and 2013 models.
MorbidMylar - 返信
I've just added some steps, for closing the iMac backup. Please revise them if needed.
But you guys need to take notice, of users cracking their display glass and getting vertical or horizontal lines, when following your guides, as the guides are VERY far from Apple's iMac Service Guides!
MorbidMylar - 返信
Please help,
unfortunately after assembly of the Display, i have seen, that the outside dark frame in front of the display is torn. Obviously, the black film has solved on one side. Although open with the original iFixit tool (cutter)
Where can i get an new black foil
Andreas - 返信
Remember to check, before you close the case, that the small clear circle where the iSight camera looks out is dust-free, especially if, as I was, you are working with a unit that was pretty dusty inside.
You could easily seal the iMac up and then to your frustration see that there are multiple specks of dust slap-bang in front of the camera lens.
Guy Hemmings - 返信
Is the IFIXIT adhesive strip secure enough for 27" iMac late 2013 model? I still see some gaps after using IFIXIT strip and am worried that the display may fell off one day.
Firstaid computers - 返信
Hello all, how does the LCD cable get disconnected from the old screen, I am afraid of breaking it!
Do I lift anything or just pull on it?
Thank you
Carlos - 返信
Hi Carlos, this is a guide for reassembly, be sure you check out the full display removal guide to learn how to disconnect those cables!
Sam Goldheart -
Make sure to remove old adhesive tape from both the iMac *and* the screen before putting new adhesive tape on.
Thomer Gil - 返信
Success. Had a couple extra screws and a post to remove pn either side of the heat sink, but all good.
Dr. Sharleen Tan - 返信
What am i getting wrong? After carefully fp;;owing this guide - my adhesive fails after a day -
mikemccloskey - 返信
Adhesive failed 6 months in. The weight of the screen also pulled the connectors off the logic board, ruining the whole machine.
Lance Seabourn Jr - 返信
The same problem than mikemccloskey, two days after mounting my display… the adhesive failed and the monitor is broken now.
Miguel Angel Cordova - 返信
i think the last step here is to allow time for the adhesive to set for at least 24 hours before using it.
Scott Oertel - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 157
今までの合計 107,063
