はじめに
Augmentez la capacité multitâche de votre iMac en ajoutant de la mémoire vive, ce qui lui permettra d'exécuter plus de programmes en même temps. La vitesse générale de votre machine n'en sera quasiment pas affectée.
必要な工具と部品
Posez l'iMac, côté écran, sur une surface plane et propre.
Desserrez les trois vis cruciformes qui fixent le panneau arrière à l'iMac.
Faites pivoter chacun des deux dispositifs d'attache de la RAM pour les éloigner de la barrette de RAM.
Retirez la barrette de RAM de son socle.
Pour remonter votre appareil, suivez ces instructions en sens inverse.
39 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
4 件のコメント
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - 返信
Can i get 6 or 8 gigs ram?
Do both the ram slots have to have ram in them
Gary Wayne - 返信
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Gary Wayne - 返信
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - 返信
The two outer screws each drive a locking bar that engage tabs on the rear panel.
They definitely need to be unscrewed.
Dale Stanbrough -
That chick MJ is sexy!!!!!
djmadcracker - 返信
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - 返信
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - 返信
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - 返信
These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
Geek Squad - 返信
