メインコンテンツにスキップ
Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261
必要な工具と部品
  1. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Batterie: 手順 1、 1の画像 1
    • Utilisez vos doigts pour pousser les deux onglets de libération de la batterie et retirez la batterie de l'ordinateur.
    Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
    amiller770 - 返信
    Can I put more than two gigabytes of RAM in?
    Noah Nsangou - 返信
    mine has 2g*2=4 gb ram in. you should be fine
    on mac forum it suggested to put 4gb and a 2gb in a1261.
    david -
    I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
    2006 17" MackBook Pro Model#A1151
    2.16 GHz Intel Core Duo
    Memory: Two 1GB 667 MHz
    Hard Drive: Corsair Force GS: SSD 128GB
    scannon - 返信
    You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
    asle -
    There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
    His quotation, (re-)cited integrally:
    Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
    Phil - 10/07/2015
    at0gjm -
    Bonjour j'ai besoin de cette bactérie que dois-je faire ?
    basile kouamé YAO - 返信
  2. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Trappe de la mémoire: 手順 2、 1の画像 1
    • Retirez les quatre vis Phillips 3,4 mm identiques à partir de la trappe de la mémoire. Ces vis ont 4 mm de diamètre de tête au lieu de 3 mm sur les vis du corps.
  3. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 3、 1の画像 1
    • Soulevez la trappe de la mémoire assez pour pouvoir la saisir, faites-la glisser vers vous pour la tirer loin du boitier.
  4. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Boîtier supérieur: 手順 4、 1の画像 1
    • Retirez les trois vis cruciformes situées dans le compartiment de la batterie, près du loquet. Apple a eu la gentillesse d'incliner légèrement ces vis pour les rendre plus faciles à retirer. Sur le A1261, ces vis ont des têtes de 4 mm de diamètre au lieu des têtes de 3 mm des vis restantes.
    One of the screws here wouldn't bite going back in. I'm 100% certain it's the same screw that came out of it but it wouldn't bite going back, neither would any of the other two in this section in that particular hole.
    Damon B - 返信
    To Damon - possibly the thread on the bottom of the upper case is obstructed.
    I found that I needed to fight the latch magnet with the right-most screw in the photo. The screw was pulled away from the hole so a magnetized screwdriver was not enough to place it. I needed tweezers to hold the screw in place until it bit.
    Yishai Sered - 返信
    No, these screws won’t bite going back in — struggled for an hour. Lost hope of success.
    Case screw holes perfectly lined-up, neatly closed body, screw threads/head are fine (Apple quality screws), perfect screwdriver.
    The left one is in, other two simply will not bite whatsoever. Slightly irritating eventually turned to madly infuriating. I have a similar, earlier model and that was smooth to replace these exact, slightly angled screws (so I have experience).
    Q: Are the centre and right-hand screws absolutely essential — or can I give up and leave them out?
    (By the time you read this, that’s what I’ll have done)(out of sheer frustration)
    Steve Arkwright - 返信
  5. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 5、 1の画像 1
    • Retirez les six vis suivantes :
    • Deux vis Torx T6 de 14,5 mm de part et d'autre du compartiment de la RAM.
    • Quatre vis cruciformes de 3,4 mm le long de la charnière.
    Note for re-assembly: For the hinge use the longest four Phillips screws.
    R L - 返信
    The Philips screws in Step 5 are longer than the other Philips screws. Would be better if the instructions differentiated them. Otherwise it is possible to use the wrong screws in Step 7 when reassembling.
    Alex - 返信
    These instructions are actually wrong. The 14.5 mm screws are for along the hinge, the 2 on either side of the RAM slot are about 10 mm.
    Andrew Patterson - 返信
  6. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 6、 1の画像 1
    • Retirez les quatre vis cruciformes de 3,4 mm sur le côté des ports de l'ordinateur.
    When reassembling, please be careful not to screw into the wrong spot. I accidentally screwed into the DVI port and it was hard to remove the screw after that. I had to disassemble the whole thing again, only to find that I couldn't remove the screw from within as it was encased. After much scraping and prodding with a sewing needle, I was able to get that screw out. Phew!
    isotope434 - 返信
  7. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 7、 1の画像 1
    • Faites pivoter l'ordinateur de 90 degrés et retirez les deux vis cruciformes à l'arrière de l'ordinateur.
    Screw on the right is shorter
    mikefal - 返信
    What are these two screws called?
    ian - 返信
  8. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 8、 1の画像 1
    • Faites de nouveau pivoter l'ordinateur de 90 degrés et retirez les quatre vis cruciformes sur le côté de l'ordinateur.
  9. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 9、 1の画像 1
    • Ne retirez pas le boîtier supérieur d'un coup sec. Le boîtier est relié à la carte mère par une nappe.
    • Soulevez l'arrière du boîtier et faites glisser vos doigts le long des côtés, en détachant le boîtier au fur et à mesure. Une fois que vous avez détaché les côtés, vous devrez peut-être faire basculer le boîtier de haut en bas pour détacher l'avant du boîtier supérieur.
    WOW this step is very hard!!! its a serious suction cup..
    nya - 返信
    Once the upper case is free...Carefully tilt the upper case from the front towards the screen as their is a ribbon cable directly beneath the keyboard and trackpad that will need to be removed in the next step.
    Troy - 返信
    Be very careful not to bend the screw tabs on the top case the perimeter screws attach to. Bending them causes them to quickly fatigue and potentially break off. When reassembling the top case, be sure the tabs are all *inside* the case before reseating it. If you get resistance, pull the case back up, check the tabs and reseat the top case again.
    Sheldon Carpenter - 返信
  10. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 10、 1の画像 1
    • Débranchez la nappe du pavé tactile et du clavier de sa prise sur la carte mère.
    • Retirez le boîtier supérieur.
    Disconnecting this cable is optional, if instead you tip up the top case ~75 degrees, propping it up with something non-metalic (wedged in or by the battery compartment). Unplugging a connector from the main circuit board always carries slight additional risk.
    amiller770 - 返信
    It's not really necessary to disconnect the trackboard/keyboard ribbon cable. You can simply lean the upper case against the LCD.
    Russ Greene - 返信
    how reconnect this cable?
    anatole - 返信
    I did this with and without step 10 (removing the upper case with detached cable). Removing the cable is risk, putting it back on was not so easy. But then, leaning the keyboard part against the LCD while replacing the hard drive is also risky.
    tobybaier - 返信
    After having successfully removed/reattached the ribbon cable several times while trying to revive this computer for back-up use the securing/release tabs on the connector broke. The connector then will not hold the cable properly and connecting fails. Tried various methods of propping the cable in the connector to get full contact but eventually all efforts failed, too. Result: essentially a dead motherboard as no replacement for the connector seems available. Sadly, not worth the extra effort to try further repairs.
    Steve colton - 返信
  11. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Écran: 手順 11、 3の画像 1 Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Écran: 手順 11、 3の画像 2 Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261, Écran: 手順 11、 3の画像 3
    • Débranchez les deux câbles d'antenne de la carte AirPort Extreme, les câbles iSight et de l'inverseur du côté gauche de la carte mère, ainsi que le câble de données de l'écran du côté droit de la carte mère. Faites attention à faire glisser les connecteurs car ils risquent d'être endommagés sinon.
    • Pour les modèles A1229 et A1212, débranchez les trois câbles d'antenne de la carte AirPort Extreme et les trois connecteurs mis en évidence sur la carte mère.
    • Sur l'A1229, l'ordre des câbles de gauche à droite est le suivant : Noir (gauche ; vers le bord du boîtier) - Gris (milieu) - Bleu (droite ; vers le milieu du boîtier.
    • Pour le modèle A1261, débranchez les deux câbles d'antenne de la carte AirPort Extreme et les trois connecteurs (voir photo) sur la carte mère.
    • Retirez avec précaution les câbles iSight et de l'inverseur en haut du ventilateur gauche et déroulez les câbles de l'antenne AirPort de la rainure du haut-parleur gauche.
    Remember to replace the little sponge-type object on top of the right-side set of 3 screws, towards the right.
    Andrew - 返信
    anybody got any advice re: how to detach the connector on that tiny little ribbon, the one on the upper left with the larger ribbon/connector alongside it? I tried and tried... gave up for fear of damaging the wires, plus concern about how difficult it might be to get it back in. Thx in adv
    firenzeitalia - 返信
    Firenzeitalia: The tiny little black one is the scariest part of the whole job. You need to use a firm spudger to slide it out to the left. Possibly even use the pointy end, but it slides out quite easily.
    The hard part is getting it to slide back in again later — especially if you have large fingers. Essentially, you’re going to have to do it blind — and by ‘feel’ — because you can’t see what you’re doing.
    Fortunately, Apple made it so that the black housing lines-up to the sides and the four tiny receptor prongs: once you’ve slid it into place and it looks correctly in, you then push down on it — to snap it in properly.
    This is the time to re-attach the keyboard (put a cloth over the screen), plug in power and turn the machine on to test you’ve done it right.
    If you’ve attached the tiny Inverter housing correctly, the screen will light up and boot as expected. If the screen remains black, remove the keyboard and cable again — gently — and check the Inverter and Display Data Cable are correctly inserted.
  12. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 12、 1の画像 1
    • Retirez les dix vis Torx T6 argentées qui fixent l'écran (cinq de chaque côté - notez que les vis intérieures des deux côtés sont plus longues et ont une tête plus fine).
    • N'oubliez pas de remplacer les embouts de charnière lors du replacement de l'écran. Les embouts sont spécifiques à leur côté, assurez-vous donc que les montants sont orientés vers le boîtier inférieur.
    To clarify the placement of the different screws:
    There are two sets of 2 on each side and two sets of 3 on the insides. The "long" screws with "flat" heads are meant for the INSIDE of the sets of 3. I will represent short screws by the letter "S" and the long screws by the letter "L":
    S S - S S L - L S S - S S
    Andrew - 返信
    But what are the measurements of the screws? Its T6 but how many millimeters long is the screw?
    Sean Love -
    The longer two (middle) screws are about 14mm and the rest (identical) are approximately 10mm.
  13. Remplacement de l'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261: 手順 13、 1の画像 1
    • Saisissez l'ensemble écran des deux côtés et soulevez-le pour le sortir de l'ordinateur.
    If you came to the Display Removal guide to replace just the LCD panel and not the entire assembly, you need to head over to the Front Bezel replacement guide.
終わりに
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
45 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en fr
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
12人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
3 件のコメント
Does any one know what the pinout is on the display connector. I am assuming that the first 4 fairly spaced out pins are power. We got a working display form a broken A1229 and are planning to use the display for our experimental purposes. Before doing that we need to know if the display is any good.
thanks
PKNT - 返信
This is my first action with a used Apple laptop A1229. I’m a Vet, Army ‘72-’75 & worked/volunteered about 30 years helping ther Vets and families along with employers match up. My “frustration” as a newbie, is which way to move the pins, up, out, lift, don’t, etc. Would be nice to have close up pics of the ends and see some arrows or descriptors telling me what to do w/o damage. I bumped a short wire that rested w/sensor of some kind on top of MB and detached it, oh well. Trying to get screen to my wife’s laptop, then remove this logic board & hope it works and install into my used A1229 17” Mac Pro. Hoping to save up and purchase a used quad core 17” but time will tell. Thanks to all of you who are putting ut info, helps folks like me.
Gregg - 返信
I hate the screen replacement.
Jayden Bentley - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 45
今までの合計 65,407
