メインコンテンツにスキップ
Remplacement de l'écran tactile et du LCD du Samsung Galaxy A5 (2017)
必要な工具と部品
ビデオインストラクション
ゴール
40 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
ian mdx
メンバー登録日: 06/30/16
8,968 ポイント
17のガイドは作成済み
9 件のコメント
Good video!!
Mandy - 返信
Good video!
I have a question though. What did you use to bull back the back partbof the phone at the end of the video? You simply heated the glue that was already there?
Mattia Rappuoli - 返信
Please answer, what is the glue you used in the video? Thanks.
tcatt - 返信
The glue used here is the B7000 glue, which can be found on this site under tools or from aliexpress.com.
However, it should be mentioned that it is not required to use other glue than the sticky tape than phone already has, unless you are serious about waterproofing. I removed 98% of all the sticky tape that was there hoping it would be easier to open later. Funny thing is that I still have to use heat lol. Hard to remove all that sticky.
lightmeupper - 返信
The tool to pull back the cover is Suction Handle
Something tells me it may work with a 40-50mm diameter suction cup from dollar store as well :-)
lightmeupper - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 53
今までの合計 68,463
