メインコンテンツにスキップ
Removing the USB connector from a moulded cable
必要な工具と部品
  1. Removing the USB connector from a moulded cable, Freeing the connector from the plastic: 手順 1、 3の画像 1 Removing the USB connector from a moulded cable, Freeing the connector from the plastic: 手順 1、 3の画像 2 Removing the USB connector from a moulded cable, Freeing the connector from the plastic: 手順 1、 3の画像 3
    • The first step is to work on removing the moulded plastic from the metal. Start with the connecting line at the side using a utility knife. Once you completely cut the plastic from the both sides, push the utility knife between the metal and plastic as in the image to remove the plastic from the metal.
  2. Removing the USB connector from a moulded cable, Removing the plastic housing: 手順 2、 2の画像 1 Removing the USB connector from a moulded cable, Removing the plastic housing: 手順 2、 2の画像 2
    • Once you pried the plastic housing from the metal part, carefully and slowly pry the plastic towards the back of the connector. The plastic will come off as in the image.
  3. Removing the USB connector from a moulded cable, Removing the fastener clips: 手順 3、 2の画像 1 Removing the USB connector from a moulded cable, Removing the fastener clips: 手順 3、 2の画像 2
    • Note the fastener clips that go round the cable as pointed. Remove the clips using a nose plier.
  4. Removing the USB connector from a moulded cable, Removing the plastic completely: 手順 4、 2の画像 1 Removing the USB connector from a moulded cable, Removing the plastic completely: 手順 4、 2の画像 2
    • In this step we completely remove the moulded plastic from the connector. Bear in mind that since the mould was hot, the plastic was in liquid form and thus dispersed throughout the connector. Remove the plastic carefully and if the plastic is stuck/stubborn, use the cable cutter to cut/remove it.
  5. Removing the USB connector from a moulded cable, Cleaning and finalizing: 手順 5、 3の画像 1 Removing the USB connector from a moulded cable, Cleaning and finalizing: 手順 5、 3の画像 2 Removing the USB connector from a moulded cable, Cleaning and finalizing: 手順 5、 3の画像 3
    • Now that we dismantled our USB connector from the moulded plastic, the remaining part is to clean up the remains -if any.
    • Before adding the connector to our spare parts, the final step is to make sure that all the pins are in working order. Visually inspect the pins and recheck they all work with a connectivity test in your multimeter.
終わりに
Since the cable is of moulded type, we cannot bring the cable to its initial state.
以下の翻訳者の皆さんにお礼を申し上げます:
tr en
100%
Tolga Balcıさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Tolga Balcı
メンバー登録日: 12/02/24
343 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 53
今までの合計 72
