メインコンテンツにスキップ
Removing the Logitech MBJ58 Scroll Wheel from its Mount
必要な工具と部品
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: 手順 1、 1の画像 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: 手順 2、 2の画像 1 Removing the Logitech MBJ58 Scroll Wheel from its Mount: 手順 2、 2の画像 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 1 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: 手順 3、 3の画像 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 手順 4、 2の画像 1 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: 手順 4、 2の画像 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 手順 5、 2の画像 1 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: 手順 5、 2の画像 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 手順 6、 3の画像 1 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 手順 6、 3の画像 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: 手順 6、 3の画像 3
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Conor Whatley
メンバー登録日: 01/11/13
510 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G14
5 メンバー
23のガイドは作成済み
2件のガイドコメント
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - 返信
Very helpful, thank you!
K.S. - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 41
今までの合計 2,001
