メインコンテンツにスキップ
Removing the HP Elitebook 6930p modem card
必要な工具と部品
  1. Removing the HP Elitebook 6930p modem card, Battery Removal: 手順 1、 3の画像 1 Removing the HP Elitebook 6930p modem card, Battery Removal: 手順 1、 3の画像 2 Removing the HP Elitebook 6930p modem card, Battery Removal: 手順 1、 3の画像 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p modem card, Keyboard: 手順 2、 3の画像 1 Removing the HP Elitebook 6930p modem card, Keyboard: 手順 2、 3の画像 2 Removing the HP Elitebook 6930p modem card, Keyboard: 手順 2、 3の画像 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p modem card: 手順 3、 3の画像 1 Removing the HP Elitebook 6930p modem card: 手順 3、 3の画像 2 Removing the HP Elitebook 6930p modem card: 手順 3、 3の画像 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p modem card: 手順 4、 3の画像 1 Removing the HP Elitebook 6930p modem card: 手順 4、 3の画像 2 Removing the HP Elitebook 6930p modem card: 手順 4、 3の画像 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p modem card, Modem card: 手順 5、 2の画像 1 Removing the HP Elitebook 6930p modem card, Modem card: 手順 5、 2の画像 2
    • Locate the modem card and remove the 2 M2.5×4.0 screws
    • The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
    • A plastic spudger may be useful in lifting the card out
    • Be careful as there is a small cable connected to the edge of the modem card closest to the LCD display
    • Disconnect the cable from the modem card to complete removal
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Richdave
メンバー登録日: 04/09/10
32,081 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,385
