メインコンテンツにスキップ
Removing the HP Elitebook 6930p Switch Cover
必要な工具と部品
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 手順 1、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 手順 1、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: 手順 1、 3の画像 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: 手順 2、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover, Keyboard: 手順 2、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover, Keyboard: 手順 2、 3の画像 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: 手順 3、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover: 手順 3、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover: 手順 3、 3の画像 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: 手順 4、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover: 手順 4、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover: 手順 4、 3の画像 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 手順 5、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 手順 5、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: 手順 5、 3の画像 3
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: 手順 6、 3の画像 1 Removing the HP Elitebook 6930p Switch Cover: 手順 6、 3の画像 2 Removing the HP Elitebook 6930p Switch Cover: 手順 6、 3の画像 3
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Richdave
メンバー登録日: 04/09/10
32,287 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,525のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 1,981
