メインコンテンツにスキップ
Removing the HP Elitebook 6930p RTC (CMOS) Battery
必要な工具と部品
  1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 手順 1、 3の画像 1 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 手順 1、 3の画像 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: 手順 1、 3の画像 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 手順 2、 3の画像 1 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 手順 2、 3の画像 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: 手順 2、 3の画像 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 3、 3の画像 1 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 3、 3の画像 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 3、 3の画像 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 4、 3の画像 1 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 4、 3の画像 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery: 手順 4、 3の画像 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: 手順 5、 2の画像 1 Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: 手順 5、 2の画像 2
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
終わりに
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Richdave
メンバー登録日: 04/09/10
32,371 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,700のガイドは作成済み
8 件のコメント
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - 返信
This didn't work for me
Depinder Bharti - 返信
I can't even boot
Hugo Escobar - 返信
cool i like the explanation
Nartey Levis - 返信
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 132
今までの合計 41,900
