メインコンテンツにスキップ
Removing the HP Compaq dx2000MT Optical (CD) Drive
必要な工具と部品
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: 手順 1、 1の画像 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 2、 2の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 2、 2の画像 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 3、 3の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 3、 3の画像 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 3、 3の画像 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 4、 3の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 4、 3の画像 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 4、 3の画像 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 手順 5、 3の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 手順 5、 3の画像 2 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: 手順 5、 3の画像 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 6、 2の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 6、 2の画像 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 7、 2の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 7、 2の画像 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 8、 3の画像 1 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 8、 3の画像 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: 手順 8、 3の画像 3
    • Remove the optical drive by sliding it out the front of the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Logan Pace
メンバー登録日: 10/12/11
2,224 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G16
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,468
