はじめに
Use this guide to learn how to remove and replace the battery.
  1. Orient the camera so that the back button panel and viewfinder are facing you.
    • Orient the camera so that the back button panel and viewfinder are facing you.
    • Push the "Battery Release" button to the side and hold.
  2. While holding the battery release button to the side, slide the battery towards you, past the release button.
    • While holding the battery release button to the side, slide the battery towards you, past the release button.
まとめ
To put the battery back in, line up the edges and gently push it back into place until it clicks.
Avery Reger
メンバー登録日: 2011年01月17日
111 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-12, Amido Winter 2011 Cal Poly, Team 1-12, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G12
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 980
