メインコンテンツにスキップ
Sony Ericsson W350a Keypad Replacement
必要な工具と部品
  1. Sony Ericsson W350a Keypad Replacement, Flip Cover: 手順 1、 1の画像 1
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
  2. Sony Ericsson W350a Keypad Replacement: 手順 2、 1の画像 1
    • Remove the cover with a slight twisting motion.
  3. Sony Ericsson W350a Keypad Replacement, Battery: 手順 3、 2の画像 1 Sony Ericsson W350a Keypad Replacement, Battery: 手順 3、 2の画像 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  4. Sony Ericsson W350a Keypad Replacement: 手順 4、 3の画像 1 Sony Ericsson W350a Keypad Replacement: 手順 4、 3の画像 2 Sony Ericsson W350a Keypad Replacement: 手順 4、 3の画像 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  5. Sony Ericsson W350a Keypad Replacement, Speaker: 手順 5、 2の画像 1 Sony Ericsson W350a Keypad Replacement, Speaker: 手順 5、 2の画像 2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  6. Sony Ericsson W350a Keypad Replacement: 手順 6、 1の画像 1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Keypad Replacement: 手順 7、 1の画像 1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  8. Sony Ericsson W350a Keypad Replacement: 手順 8、 1の画像 1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  9. Sony Ericsson W350a Keypad Replacement: 手順 9、 2の画像 1 Sony Ericsson W350a Keypad Replacement: 手順 9、 2の画像 2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  10. Sony Ericsson W350a Keypad Replacement: 手順 10、 2の画像 1 Sony Ericsson W350a Keypad Replacement: 手順 10、 2の画像 2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
  11. Sony Ericsson W350a Keypad Replacement, Keypad: 手順 11、 3の画像 1 Sony Ericsson W350a Keypad Replacement, Keypad: 手順 11、 3の画像 2 Sony Ericsson W350a Keypad Replacement, Keypad: 手順 11、 3の画像 3
    • Disconnect the ribbon cable from its connection until the keypad "pops" off.
    • Remove the keypad from the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Ldellos
メンバー登録日: 03/12/12
112 ポイント
3のガイドは作成済み
チーム
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S1G4
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,252
