メインコンテンツにスキップ
Removing Side Panel on Canon Optura 100MC
必要な工具と部品
  1. Removing Side Panel on Canon Optura 100MC, Hand Strap: 手順 1、 1の画像 1
    • Orient the camera with the hand strap facing you.
    • Remove the two 4mm #00 Philips screws.
    • When the screws are removed, the black plate will easily come off as well as the two metal plates under it. Be careful to not let them fall or get lost.
  2. Removing Side Panel on Canon Optura 100MC: 手順 2、 1の画像 1
    • Lift the strap up.
  3. Removing Side Panel on Canon Optura 100MC, Battery: 手順 3、 1の画像 1
    • Orient the camera so that the back button panel and viewfinder are facing you.
    • Push the "Battery Release" button to the side and hold.
  4. Removing Side Panel on Canon Optura 100MC: 手順 4、 1の画像 1
    • While holding the battery release button to the side, slide the battery towards you, past the release button.
  5. Removing Side Panel on Canon Optura 100MC, The side of the Device: 手順 5、 1の画像 1
    • Orient the camera so that the viewfinder is on your left and the lens is on your right.
    • Remove the 4mm #00 Phillips screw.
  6. Removing Side Panel on Canon Optura 100MC: 手順 6、 1の画像 1
    • Reorient the camera with the back button pad and viewfinder towards you.
    • Remove the three 4mm #00 Phillips screws shown on the rear face of camcorder.
  7. Removing Side Panel on Canon Optura 100MC: 手順 7、 2の画像 1 Removing Side Panel on Canon Optura 100MC: 手順 7、 2の画像 2
    • Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown.
    • The Battery Should be removed at this point, please ignore it in the picture.
  8. Removing Side Panel on Canon Optura 100MC: 手順 8、 1の画像 1
    • Remove the 4mm #00 Phillips screw located to the right of the LCD release switch.
  9. Removing Side Panel on Canon Optura 100MC: 手順 9、 1の画像 1
    • Open the LCD by using the release switch.
    • Reorient the camera with the playback button pad and edge of LCD screen facing you.
    • Remove the 4mm #00 Phillips screw shown.
  10. Removing Side Panel on Canon Optura 100MC: 手順 10、 1の画像 1
    • Reorient the camera with the top facing you. The side with the LCD screen should be on the right and the other side panel should be on the right.
    • Open the pop up flash on the top of the camcorder.
    • A loud clicking noise is expected.
  11. Removing Side Panel on Canon Optura 100MC: 手順 11、 2の画像 1 Removing Side Panel on Canon Optura 100MC: 手順 11、 2の画像 2
    • Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left.
    • Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
  12. Removing Side Panel on Canon Optura 100MC: 手順 12、 1の画像 1
    • Remove 4mm #00 Phillips screw.
  13. Removing Side Panel on Canon Optura 100MC: 手順 13、 1の画像 1
    • Reorient camera with lens facing you.
    • Remove the #00 Philips 4mm screw shown on the hinge of the tape deck cover.
  14. Removing Side Panel on Canon Optura 100MC: 手順 14、 2の画像 1 Removing Side Panel on Canon Optura 100MC: 手順 14、 2の画像 2
    • To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you.
  15. Removing Side Panel on Canon Optura 100MC: 手順 15、 2の画像 1 Removing Side Panel on Canon Optura 100MC: 手順 15、 2の画像 2
    • Close the tape deck by gently pushing it toward the body of the camera.
    • Slide and remove the plastic cover on the bottom right, exposing the interface shown.
  16. Removing Side Panel on Canon Optura 100MC: 手順 16、 2の画像 1 Removing Side Panel on Canon Optura 100MC: 手順 16、 2の画像 2
    • Gently pull the front plastic cover towards you to remove.
  17. Removing Side Panel on Canon Optura 100MC: 手順 17、 1の画像 1
    • Remove 2 Philips #00 4mm screw shown.
  18. Removing Side Panel on Canon Optura 100MC: 手順 18、 1の画像 1
    • Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
    • Holding the camera as shown,remove the 4mm #00 Phillips screw.
  19. Removing Side Panel on Canon Optura 100MC: 手順 19、 1の画像 1
    • Remove the 4 Philips #00 4mm screws shown.
  20. Removing Side Panel on Canon Optura 100MC: 手順 20、 1の画像 1
    • Reorient the camera with the lens facing you.
    • Gently pull the side panel of the camera to the right to remove.
    • Be aware that that there are wires connecting the cover to the body of the device, so the side cover will not come off entirely.
  21. Removing Side Panel on Canon Optura 100MC: 手順 21、 1の画像 1
    • The side of the device should now be open as shown. Again, there are wire connections between the side cover and the body of the camcorder. Do not separate the two entirely!
終わりに
作成者
4人の作成者と共同で作成されました。
Jeanette Neethling
メンバー登録日: 01/19/11
531 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 1-12, Amido Winter 2011 Cal Poly, Team 1-12, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G12
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 13
今までの合計 883
