メインコンテンツにスキップ
Removing RAM from HP Elitebook 6930p
必要な工具と部品
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: 手順 1、 3の画像 1 Removing RAM from HP Elitebook 6930p, Battery Removal: 手順 1、 3の画像 2 Removing RAM from HP Elitebook 6930p, Battery Removal: 手順 1、 3の画像 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: 手順 2、 3の画像 1 Removing RAM from HP Elitebook 6930p, Keyboard: 手順 2、 3の画像 2 Removing RAM from HP Elitebook 6930p, Keyboard: 手順 2、 3の画像 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: 手順 3、 3の画像 1 Removing RAM from HP Elitebook 6930p: 手順 3、 3の画像 2 Removing RAM from HP Elitebook 6930p: 手順 3、 3の画像 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing RAM from HP Elitebook 6930p: 手順 4、 3の画像 1 Removing RAM from HP Elitebook 6930p: 手順 4、 3の画像 2 Removing RAM from HP Elitebook 6930p: 手順 4、 3の画像 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing RAM from HP Elitebook 6930p, RAM: 手順 5、 2の画像 1 Removing RAM from HP Elitebook 6930p, RAM: 手順 5、 2の画像 2
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
終わりに
21 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Richdave
メンバー登録日: 04/09/10
32,287 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,525のガイドは作成済み
7 件のコメント
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - 返信
I agree with above comment, weird thing to do.
S Cleaver - 返信
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - 返信
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - 返信
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 52
今までの合計 30,790
