メインコンテンツにスキップ
Removing Playstation 2 Slimline SCPH-7500x Outer Shell
必要な工具と部品
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 2、 1の画像 1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 3、 3の画像 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 3、 3の画像 2 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 3、 3の画像 3
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 4、 2の画像 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 4、 2の画像 2
    • Remove the sticker and then remove the 6th foot.
  4. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 5、 3の画像 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 5、 3の画像 2 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 5、 3の画像 3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 6、 3の画像 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 6、 3の画像 2 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 6、 3の画像 3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: 手順 7、 1の画像 1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
終わりに
9 の人々がこのガイドを完成させました。
作成者
20人の作成者と共同で作成されました。
Jared Hirata
メンバー登録日: 04/09/13
880 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G4
3 メンバー
28のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 2,532
