メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Removing Olympus FE-210 Rear Casing
必要な工具と部品
    1. Removing Olympus FE-210 Rear Casing, Battery: 手順 1、 2の画像 1 Removing Olympus FE-210 Rear Casing, Battery: 手順 1、 2の画像 2
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
      FixBotに聞いてみる
      コメントを追加
    2. Removing Olympus FE-210 Rear Casing: 手順 2、 2の画像 1 Removing Olympus FE-210 Rear Casing: 手順 2、 2の画像 2
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
      FixBotに聞いてみる
      コメントを追加
    1. Removing Olympus FE-210 Rear Casing, Front Casing: 手順 3、 3の画像 1 Removing Olympus FE-210 Rear Casing, Front Casing: 手順 3、 3の画像 2 Removing Olympus FE-210 Rear Casing, Front Casing: 手順 3、 3の画像 3
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
      FixBotに聞いてみる
      コメントを追加
    2. Removing Olympus FE-210 Rear Casing: 手順 4、 3の画像 1 Removing Olympus FE-210 Rear Casing: 手順 4、 3の画像 2 Removing Olympus FE-210 Rear Casing: 手順 4、 3の画像 3
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
      FixBotに聞いてみる
      コメントを追加
    1. Removing Olympus FE-210 Rear Casing, Rear Casing: 手順 5、 1の画像 1
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Removing Olympus FE-210 Rear Casing: 手順 6、 3の画像 1 Removing Olympus FE-210 Rear Casing: 手順 6、 3の画像 2 Removing Olympus FE-210 Rear Casing: 手順 6、 3の画像 3
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Matt
メンバー登録日: 01/25/11
826 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G36
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 32
今までの合計 3,187
