はじめに
Removing and replacing the battery is usually the first step towards fixing your camera.
  1. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries.
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. The batteries will slide right out. When putting new batteries in, make sure they are pointing the right direction.
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
まとめ
2 の人々がこのガイドを完成させました。
Matt
メンバー登録日: 2011年01月25日
781 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G36
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 11
今までの合計 2,887
