メインコンテンツにスキップ
はじめに
The screen of the Nokia 3100b is prone to cracking. This guide shows you how to access the screen and remove it.
パーツ
パーツは指定されていません。
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  6. Separate the front cover from the main body of the phone.
    • Separate the front cover from the main body of the phone.
    • Set the front cover, as indicated, aside.
  7. Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
    • Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
    • Removing the screws in this order prevents any unnecessary torsion on the circuit board. Be sure to remove the screws in the order indicated.
  8. Pull the screen assembly from the base of the phone.
    • Pull the screen assembly from the base of the phone.
    • Set the base of the phone, as indicated, aside.
  9. Carefully lift the keypad portion of the screen assembly from the circuit board.
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  10. Separate the screen from the circuit board.
    • Separate the screen from the circuit board.
    • Note the components circled in orange. These will need to be reconnected during reassembly in order for the screen to function.
    • Set the circuit board, as indicated, aside.
    • Remember to reconnect the screen to the circuit board when reassembling!
  11. Gently push down on the screen to pop it off of the assembly.
    • Gently push down on the screen to pop it off of the assembly.
  12. When the screen falls out the assembly, two white tabs will fall out with it.
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
まとめ
Sterling Fuentes
メンバー登録日: 2010年04月09日
61 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G64
3 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,617
