はじめに
This installation guide will help you remove the rear and front casing of your Nikon Coolpix 4600.
パーツ
パーツは必要ありません。
  1. Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Carefully pull the front and back case apart.
    • Carefully pull the front and back case apart.
      • The front case is attached to internal components and cannot be removed independently.
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
まとめ
Nathan Sperling
メンバー登録日: 2012年05月08日
89 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G43
5 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,210
