メインコンテンツにスキップ
Removing HP Compaq dx2000MT Power Supply
必要な工具と部品
  1. Removing HP Compaq dx2000MT Power Supply, Removing the HP Compaq dx2000MT Case Doors: 手順 1、 1の画像 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT Power Supply: 手順 2、 2の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 2、 2の画像 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT Power Supply: 手順 3、 3の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 3、 3の画像 2 Removing HP Compaq dx2000MT Power Supply: 手順 3、 3の画像 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT Power Supply: 手順 4、 3の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 4、 3の画像 2 Removing HP Compaq dx2000MT Power Supply: 手順 4、 3の画像 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT Power Supply, Power Supply: 手順 5、 3の画像 1 Removing HP Compaq dx2000MT Power Supply, Power Supply: 手順 5、 3の画像 2 Removing HP Compaq dx2000MT Power Supply, Power Supply: 手順 5、 3の画像 3
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  6. Removing HP Compaq dx2000MT Power Supply: 手順 6、 2の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 6、 2の画像 2
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  7. Removing HP Compaq dx2000MT Power Supply: 手順 7、 3の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 7、 3の画像 2 Removing HP Compaq dx2000MT Power Supply: 手順 7、 3の画像 3
    • Remove the 4 Torx T15 screws from the rear of the power supply
  8. Removing HP Compaq dx2000MT Power Supply: 手順 8、 2の画像 1 Removing HP Compaq dx2000MT Power Supply: 手順 8、 2の画像 2
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Logan Pace
メンバー登録日: 10/12/11
2,224 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G16
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 33
今までの合計 3,373
