はじめに
Ever want to disassemble and reassemble your Delphi MyFi XM2GO portable XM radio? Follow this guide to learn how to remove the motherboard (PCB logic board) of the Delphi MyFi XM2GO portable XM radio. You will need a Torx T6 screwdriver to complete this guide. Warning: you may have to use your fingernails to pry off certain parts.
必要な工具と部品
Locate the large button on the top of the device.
Push down on the button and slide the cover away from the button.
Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
ある他の人がこのガイドを完成しました。
