必要な工具と部品
Locate the large button on the top of the device.
Push down on the button and slide the cover away from the button.
Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
The logic board must be exposed to begin.
Flip the device over (see second picture).
Locate the white ribbon connector attached to the keyboard.
Catch the sides of the connector with fingernails and pull outward.
After the latch is pulled out, the ribbon cable is free to slide out of the connector housing.
もう少しです!
終わりに
