メインコンテンツにスキップ
ツール
ツールは指定されていません。
パーツ
パーツは指定されていません。
  1. Turn over the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
    • Turn over the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Locate the large button on the top back of the device. Press this button at the top while making a firm grip on the battery cover. As the button is pressed, move the cover towards the bottom of the device.
    • Locate the large button on the top back of the device.
    • Press this button at the top while making a firm grip on the battery cover.
    • As the button is pressed, move the cover towards the bottom of the device.
    • The battery removal tab may pop up during the cover removal process.
  4. Holding the device, grab the tab with thumb and index figure. Pull down on the tab to move the battery block a few millimeters towards the bottom of the device to unlock the latch at the top. After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
    • Holding the device, grab the tab with thumb and index figure.
    • Pull down on the tab to move the battery block a few millimeters towards the bottom of the device to unlock the latch at the top.
    • After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
まとめ
Scott Byer
メンバー登録日: 2012年03月09日
61 ポイント
5のガイドは作成済み
チーム
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S1G2
3 メンバー
9のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,699
