メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Place laptop upside down on a clean flat surface. Remove 2ea M2.5 x 5 mm screws.
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Use a spudger to lift the notched right edge of the hinge cover, and pry it loose You need to lay the LCD screen down flat to allow the hinge cover to be lifted off Lift the hinge cover off and set aside
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. Remove 4ea  M2 x 3mm keyboard screws Lift up keyboard from the rear to expose the connector below Disconnect the keyboard ribbon cable from the mother board
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. Remove 1ea M2.5 x 8mm screw holding the EMI shield in place Remove the EMI shield to expose the LCD ribbon cable Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed Remove 2e M2.5 x 5mm screws from each hinge bracket The Display Assembly can now be lifted free of the laptop body
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
  8. Position the computer upside down. Remove the twelve M2.5 x 8-mm screws.
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  9. Position the computer keyboard side up. Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
終わりに
2 の人々がこのガイドを完成させました。
Teja
メンバー登録日: 2010年04月27日
98 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G2
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 6,831
