メインコンテンツにスキップ
Removing Dell Inspiron 1150 Optical drive
必要な工具と部品
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 手順 1、 3の画像 1 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 手順 1、 3の画像 2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: 手順 1、 3の画像 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 手順 2、 2の画像 1 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: 手順 2、 2の画像 2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: 手順 3、 2の画像 1 Removing Dell Inspiron 1150 Optical drive: 手順 3、 2の画像 2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 手順 4、 3の画像 1 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 手順 4、 3の画像 2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: 手順 4、 3の画像 3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
終わりに
作成者
14人の作成者と共同で作成されました。
Daniel
メンバー登録日: 04/25/10
87 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G2
4 メンバー
9のガイドは作成済み
コメント 1 件
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 20
今までの合計 5,908
