パーツ
パーツは必要ありません。
  1. Flip the keyboard upside down so the bottom is angled towards you.
    • Flip the keyboard upside down so the bottom is angled towards you.
  2. Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
    • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove the bottom panel by lifting the bottom panel up and outward from yourself.
    • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  5. Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
    • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
    • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
まとめ
ある他の人がこのガイドを完成しました。
Jimmy Winne
メンバー登録日: 2012年10月04日
446 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G16
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,339
