メインコンテンツにスキップ
Removing Canon PowerShot A550 Front and Back Covers
必要な工具と部品
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 手順 1、 3の画像 1 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 手順 1、 3の画像 2 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: 手順 1、 3の画像 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: 手順 2、 1の画像 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: 手順 3、 1の画像 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: 手順 4、 2の画像 1 Removing Canon PowerShot A550 Front and Back Covers: 手順 4、 2の画像 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: 手順 5、 1の画像 1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: 手順 6、 3の画像 1 Removing Canon PowerShot A550 Front and Back Covers: 手順 6、 3の画像 2 Removing Canon PowerShot A550 Front and Back Covers: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: 手順 7、 1の画像 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Shaelyn Thomas
メンバー登録日: 04/19/11
332 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G6
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 28
今までの合計 4,323
