Place the computer monitor face down on a safe, harmless surface.
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
These tabs lock the module in place and releasing them will cause the module to "pop" up.
Remove the RAM module from the iMac.
Open the base by carefully pulling straight off, do not rotate the cover.
Open slowly to ensure that no cables are damaged or disconnected.
Squeeze the small black tab and wiggle gently to remove the colored power cable.
Do not pull directly on the colored wires.
Do not remove black grounding wire.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
