はじめに
We will unscrew the bottom faceplate, then remove the base to access the internal components.
必要な工具と部品
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
もう少しです!
終わりに
10 の人々がこのガイドを完成させました。
