メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Removing Aftermarket Vehicle Window Tinting
必要な工具と部品
  1. Removing Aftermarket Vehicle Window Tinting, Before Photos: 手順 1、 3の画像 1 Removing Aftermarket Vehicle Window Tinting, Before Photos: 手順 1、 3の画像 2 Removing Aftermarket Vehicle Window Tinting, Before Photos: 手順 1、 3の画像 3
    • This is what your window will look like before.
    • And the third photo shows what it will look like after!
    FixBotに聞いてみる
    コメントを追加
  2. Removing Aftermarket Vehicle Window Tinting: 手順 2、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 2、 2の画像 2
    • Roll down the window about 1/4 of the way so you can start to remove the tint from the top.
    FixBotに聞いてみる
    コメントを追加
  3. Removing Aftermarket Vehicle Window Tinting: 手順 3、 3の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 3、 3の画像 2 Removing Aftermarket Vehicle Window Tinting: 手順 3、 3の画像 3
    • Heat the area with a heat gun at the window's edge.
    • Start by using the low setting on the heat gun to gradually heat the surface. After the area has warmed up, you can switch to high heat to make it easier to remove the film.
    • Use the razor blade to peel a small area of the tint film up.
    FixBotに聞いてみる
    コメントを追加
  4. Removing Aftermarket Vehicle Window Tinting: 手順 4、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 4、 2の画像 2
    • Once you've peeled enough with the razor blade to use your fingers, heat the area, then peel with your fingers.
    • Don't pull with your fingers and heat the area with the gun simultaneously. You'll burn yourself.
    • Heat the film angling the heat gun up. This will ensure that the film will not rip easily.
    FixBotに聞いてみる
    コメントを追加
  5. Removing Aftermarket Vehicle Window Tinting: 手順 5、 1の画像 1
    • When you've pulled enough film off so that you don't burn your fingers while simultaneously pulling, use a back-and-forth motion with the heat gun along the area where the film is still on the window while pulling on the film. (See next step)
    FixBotに聞いてみる
    コメントを追加
    • How to heat the area with the heat gun.
    FixBotに聞いてみる
    コメントを追加
  6. Removing Aftermarket Vehicle Window Tinting: 手順 7、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 7、 2の画像 2
    • Once you have removed the film from the top of the window, you can roll up the window.
    • Continue doing a back-and-forth motion and pulling on the film until all of the film comes off.
    • If the film rips, no worries. Just continue. You can heat up those sections and remove them later.
    FixBotに聞いてみる
    コメントを追加
  7. Removing Aftermarket Vehicle Window Tinting: 手順 8、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 8、 2の画像 2
    • Once you have removed all of the film, spray the window with glass cleaner and clean the window with either a rag or paper towel.
    FixBotに聞いてみる
    コメントを追加
  8. Removing Aftermarket Vehicle Window Tinting: 手順 9、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 9、 2の画像 2
    • For areas where some residue is still on the window, spray the area with glass cleaner and use the razor blade to scrape the area to remove the residue.
    • For really tough residue, use Goo Gone in lieu of glass cleaner.
    FixBotに聞いてみる
    コメントを追加
  9. Removing Aftermarket Vehicle Window Tinting: 手順 10、 2の画像 1 Removing Aftermarket Vehicle Window Tinting: 手順 10、 2の画像 2
    • First photo: Before
    • Second photo: After
    FixBotに聞いてみる
    コメントを追加
  10. Removing Aftermarket Vehicle Window Tinting, Before and After: 手順 11、 2の画像 1 Removing Aftermarket Vehicle Window Tinting, Before and After: 手順 11、 2の画像 2
    FixBotに聞いてみる
    コメントを追加
終わりに
You are finished! Repeat the steps in this guide for every window you wish to remove the tinting.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
S.I. Dalton
メンバー登録日: 09/05/24
1,728 ポイント
4のガイドは作成済み
チーム
Apple fan boys Apple fan boys人のメンバー
Community
57 メンバー
56のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 53
今までの合計 765
