はじめに
There are a few reasons to want to take out your backseat:
  • Clean under it.
  • Put in a new seat.
  • To reach the rear speakers.
And this is a short and easy guide on how to remove the seat. Anyone can do it.
  1. Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
    • Underneath the back seat on both sides will be either a tab or a lever (In mine, it has tabs)
  2. Pull/lift the tab/lever on each side to release the seat.
    • Pull/lift the tab/lever on each side to release the seat.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Lift up and remove the seat.
    • Lift up and remove the seat.
  5. Clean the seat or do whatever it is you wish to do. Clean the seat or do whatever it is you wish to do.
    • Clean the seat or do whatever it is you wish to do.
  6. Put the seat back on. As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back. As shown in the second image is a hook that goes into the base of the backseat.
    • Put the seat back on.
    • As shown in the first image, be sure to put the seat belt and buckles through the slit on the seat. Otherwise, you will be without seat belts in the back.
    • As shown in the second image is a hook that goes into the base of the backseat.
    • The third image is of the tab that the hook on the seat goes into.
    • When you line up the hooks and tabs, push down hard. You will hear a click when the hooks are fitted into the tabs.
    • And there, your seat has been taken out and put back in! Good job!
まとめ
Your seat has now been taken out and put back in. Not hard, eh?
4 の人々がこのガイドを完成させました。
Scratchitory
メンバー登録日: 2013年04月25日
917 ポイント
3のガイドは作成済み
コメント1件
Will back seats out of a 2004 or 5 grand Prix gt fit in 2003 SS Monte Carlo. Help please
Perry monahan - 返信
コメントを追加する
統計データを表示:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 81
今までの合計 7,193
