メインコンテンツにスキップ
Removing 1994-2001 Acura Integra Center Console
必要な工具と部品
  1. Removing 1994-2001 Acura Integra Center Console, Center Console: 手順 1、 2の画像 1 Removing 1994-2001 Acura Integra Center Console, Center Console: 手順 1、 2の画像 2
    • Remove the two Phillips screws at the very rear of the center console near the floor.
  2. Removing 1994-2001 Acura Integra Center Console: 手順 2、 2の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 2、 2の画像 2
    • Insert a small flathead screwdriver into the notch at the driver's side rear corner of the screw cover directly below the parking brake lever and pry it off.
    • Remove the two Phillips screws that were underneath the screw cover.
  3. Removing 1994-2001 Acura Integra Center Console: 手順 3、 2の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 3、 2の画像 2
    • Grab the bottom of the rear portion of the console and lift up and away from the front of the car.
    • Remove the rear portion of the center console.
  4. Removing 1994-2001 Acura Integra Center Console: 手順 4、 2の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 4、 2の画像 2
    • Pull the ash tray out from the center console until it stops.
    • Push down on the metal plate at the top of the ash tray and continue to pull the tray out until it is completely removed.
  5. Removing 1994-2001 Acura Integra Center Console: 手順 5、 3の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 5、 3の画像 2 Removing 1994-2001 Acura Integra Center Console: 手順 5、 3の画像 3
    • Remove two Phillips screws from behind the ash tray.
    • Remove the lower portion of the console that contains the cigarette lighter from the rest of the center console.
    • Disconnect the electrical connector for the cigarette lighter by first depressing the tab on top, and then pulling directly out of the socket.
  6. Removing 1994-2001 Acura Integra Center Console: 手順 6、 3の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 6、 3の画像 2 Removing 1994-2001 Acura Integra Center Console: 手順 6、 3の画像 3
    • Remove four Phillips screws that hold the side pieces of the front portion of the console in place.
    • Two below the radio pocket.
    • Two on the faces of the side pieces, one on either side.
  7. Removing 1994-2001 Acura Integra Center Console: 手順 7、 2の画像 1 Removing 1994-2001 Acura Integra Center Console: 手順 7、 2の画像 2
    • Remove the shift knob by unscrewing it counter-clockwise.
    • Lift the front portion of the center console up and away from the front of the car.
    • It may be necessary to pull the emergency brake handle up further to create enough room to remove the front portion of the center console.
終わりに
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
David Hodson
メンバー登録日: 04/13/10
150,882 ポイント
127のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 26
今までの合計 19,210
