メインコンテンツにスキップ
Remove the Write Protect Screw
必要な工具と部品
  1. Remove the Write Protect Screw, Remove the rubber pads: 手順 1、 2の画像 1 Remove the Write Protect Screw, Remove the rubber pads: 手順 1、 2の画像 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Remove the Write Protect Screw, Removing the bottom panel: 手順 2、 3の画像 1 Remove the Write Protect Screw, Removing the bottom panel: 手順 2、 3の画像 2 Remove the Write Protect Screw, Removing the bottom panel: 手順 2、 3の画像 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Remove the Write Protect Screw, Pop it open: 手順 3、 2の画像 1 Remove the Write Protect Screw, Pop it open: 手順 3、 2の画像 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 手順 4、 2の画像 1 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): 手順 4、 2の画像 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - 返信
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - 返信
    How to check if screw is already removed or not? By not opening its back.
    Abdullah Ishfaq - 返信
終わりに
15 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kevin Fessler
メンバー登録日: 04/16/16
1,770 ポイント
4のガイドは作成済み
4 件のコメント
removing this will allow me to boot and install windows?
john Akday - 返信
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy -
Acer R752TN write protect screw location?
Fredrik Løvås - 返信
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 139
過去 30 日: 590
今までの合計 36,052
