メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Remove the Screen
必要な工具と部品
  1. Remove the Screen, Remove Screws: 手順 1、 3の画像 1 Remove the Screen, Remove Screws: 手順 1、 3の画像 2 Remove the Screen, Remove Screws: 手順 1、 3の画像 3
    • Remove the screws from the bottom, right, and left side of camera.
    FixBotに聞いてみる
  2. Remove the Screen, Remove back: 手順 2、 1の画像 1
    • Remove the back of the camera, this may require force.
    FixBotに聞いてみる
  3. Remove the Screen, Remove Metal Bracket: 手順 3、 1の画像 1
    • Unscrew the right metal bracket of the viewing lens
    FixBotに聞いてみる
  4. Remove the Screen, Remove front of camera: 手順 4、 2の画像 1 Remove the Screen, Remove front of camera: 手順 4、 2の画像 2
    • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
    FixBotに聞いてみる
  5. Remove the Screen: 手順 5、 2の画像 1 Remove the Screen: 手順 5、 2の画像 2
    • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
    FixBotに聞いてみる
  6. Remove the Screen: 手順 6、 1の画像 1
    • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
    FixBotに聞いてみる
  7. Remove the Screen: 手順 7、 1の画像 1
    • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
    FixBotに聞いてみる
  8. Remove the Screen, Remove the Screen: 手順 8、 1の画像 1
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
    FixBotに聞いてみる
  9. Remove the Screen: 手順 9、 1の画像 1
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
    FixBotに聞いてみる
  10. Remove the Screen: 手順 10、 1の画像 1
    • Pull out the red wire and white wire attaching the screen to the motherboard.
    FixBotに聞いてみる
  11. Remove the Screen: 手順 11、 1の画像 1
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
    FixBotに聞いてみる
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Melissa
メンバー登録日: 02/12/13
246 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-2, Buehl Spring 2013 Ohio State, Team 1-2, Buehl Spring 2013人のメンバー
OSU-BUEHL-S13S1G2
2 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 81
今までの合計 716
