メインコンテンツにスキップ
Remington S5500 Power Supply Cable Removal
必要な工具と部品
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: 手順 1、 2の画像 1 Remington S5500 Power Supply Cable Removal, Power Supply Cable: 手順 1、 2の画像 2
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: 手順 2、 3の画像 1 Remington S5500 Power Supply Cable Removal: 手順 2、 3の画像 2 Remington S5500 Power Supply Cable Removal: 手順 2、 3の画像 3
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: 手順 3、 2の画像 1 Remington S5500 Power Supply Cable Removal: 手順 3、 2の画像 2
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Remington S5500 Power Supply Cable Removal: 手順 4、 2の画像 1 Remington S5500 Power Supply Cable Removal: 手順 4、 2の画像 2
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Benjamin Yohe
メンバー登録日: 07/11/18
303 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G3, Wilson Summer 2018 IUPUI, Team S3-G3, Wilson Summer 2018人のメンバー
IUPUI-WILSON-SU18S3G3
5 メンバー
2のガイドは作成済み
6 件のコメント
Excelente trabajo! Muchas gracias por la información!
Ronnetto - 返信
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - 返信
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - 返信
part number would be helpful?
Steven Lamprell - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 73
今までの合計 6,653
