メインコンテンツにスキップ
Remington MB4040 Thermal Switch Replacement
必要な工具と部品
  1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 手順 1、 3の画像 1 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 手順 1、 3の画像 2 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: 手順 1、 3の画像 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 手順 2、 2の画像 1 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: 手順 2、 2の画像 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 1 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 2 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 手順 4、 2の画像 1 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): 手順 4、 2の画像 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 手順 5、 2の画像 1 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: 手順 5、 2の画像 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 手順 6、 2の画像 1 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: 手順 6、 2の画像 2
  7. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: 手順 7、 1の画像 1
    • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
    • Use a low temperature RTV to readhere the thermal switch to the battery.
    • Remove the soldering holding the thermal switch to the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cameron Carnahan
メンバー登録日: 01/20/15
1,082 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S1G5
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 22
今までの合計 3,027
