メインコンテンツにスキップ
Refrigerator Handle with No Drills Installation
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 手順 1、 3の画像 1 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 手順 1、 3の画像 2 Refrigerator Handle with No Drills Installation, Refrigerator Handle with No Drills Installation: 手順 1、 3の画像 3
    • Use a clean sponge or damp lint free cloth to apply the handle to the surface.
    • Soapy water or other mild cleansers may be used to clean the surface from all grease or grime.
    • Preferably use cold or luke warm water.
  2. Refrigerator Handle with No Drills Installation: 手順 2、 3の画像 1 Refrigerator Handle with No Drills Installation: 手順 2、 3の画像 2 Refrigerator Handle with No Drills Installation: 手順 2、 3の画像 3
    • Gently clean the surface of refrigerator where handle will be applied.
    • Ensure the surface is completely dry before application.
  3. Refrigerator Handle with No Drills Installation: 手順 3、 3の画像 1 Refrigerator Handle with No Drills Installation: 手順 3、 3の画像 2 Refrigerator Handle with No Drills Installation: 手順 3、 3の画像 3
    • Clean the bottom of the handle's suction cups with a damp sponge or lint-free towel.
    • Ensure the surface is completely dry up before application.
  4. Refrigerator Handle with No Drills Installation: 手順 4、 1の画像 1
    • Once both surfaces are dry, place the handle with suction cups facing the refrigerator.
    • Position the handle on the side you would open the refrigerator.
  5. Refrigerator Handle with No Drills Installation: 手順 5、 1の画像 1
    • Position the handle vertically and at an appropriate height.
    • The height is up to your own personal preference.
  6. Refrigerator Handle with No Drills Installation: 手順 6、 2の画像 1 Refrigerator Handle with No Drills Installation: 手順 6、 2の画像 2
    • Apply pressure to both ends of the handle for approximately 15 seconds.
  7. Refrigerator Handle with No Drills Installation: 手順 7、 3の画像 1 Refrigerator Handle with No Drills Installation: 手順 7、 3の画像 2 Refrigerator Handle with No Drills Installation: 手順 7、 3の画像 3
    • Lock the suction cups in place by pushing down on the hatches.
    • Depending on manufacturer, locking the suction handles may differ in method.
  8. Refrigerator Handle with No Drills Installation: 手順 8、 2の画像 1 Refrigerator Handle with No Drills Installation: 手順 8、 2の画像 2
    • Slowly release the handle.
    • If handle detaches, repeat steps 4-8 until successful.
終わりに
作成者
3人の作成者と共同で作成されました。
Jaskaran Buttar
メンバー登録日: 09/29/15
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-7, Green Fall 2015 Cal Poly, Team 10-7, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G7
3 メンバー
3のガイドは作成済み
コメント 1 件
Help to fix a big hole where the door is holding on door falling off
Joya Hall - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 259
