はじめに
Esta guía te enseña a remover el panel trasero del Nintendo 2DS. Esta guía demuestra como remover los tornillos que sujetan el panel trasero para poder tener acceso a las otras partes de la consola Nintendo 2DS.
必要な工具と部品
Retira los diez tornillos Phillips que sostienen el panel posterior de la consola.
Con cuidado, levanta el panel hacia arriba.
Usa tus uñas o la punta plana de una espátula para voltear el conector que asegura el cable plano a la tarjeta madre.
Remueve el cable del conector.
You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
Blackbeard - 返信
I agree, this is what the guide i followed said to do and since I was disconnecting all the other ribbon cables it made perfect sense to do it that way.
Lin -
pay attention: my 2ds dropped it's lens covers at this step
Likewise, I used a tiny drop of glue to put the lens back in place. Take care not to dirty the lens.
The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
Agreed, ribbon cable looks upside down in picture
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
Little Mac - 返信
I used a husky with changeable heads, you could probably find one on amazon
Minecrafter Pig -
These screws aren't Phillips, they're JIS, if you use a Phillips head you can and will strip the screws, please update this as it can cause more harm to people's systems than good if they get stripped.
Sneakii - 返信
