メインコンテンツにスキップ
Dell Inspiron 15 5565 Display Assembly Replacement
必要な工具と部品
  1. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Battery Cable: 手順 1、 1の画像 1
  2. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Display Cable: 手順 2、 1の画像 1
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: 手順 3、 2の画像 1 Dell Inspiron 15 5565 Display Assembly Replacement, Disconnect the Display Cable: 手順 3、 2の画像 2
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15 5565 Display Assembly Replacement, Remove the Screws: 手順 4、 1の画像 1
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15 5565 Display Assembly Replacement, Open the Display Hinges: 手順 5、 1の画像 1
    • Open the display hinges.
  6. Dell Inspiron 15 5565 Display Assembly Replacement, Lifting the Assembly: 手順 6、 1の画像 1
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15 5565 Display Assembly Replacement, Placing the Palm Rest: 手順 7、 1の画像 1
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15 5565 Display Assembly Replacement, Press the Hinges Down: 手順 8、 1の画像 1
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 5565 Display Assembly Replacement, Replace the Screws: 手順 9、 1の画像 1
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 5565 Display Assembly Replacement, Routing the Display Cable: 手順 10、 1の画像 1
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: 手順 11、 2の画像 1 Dell Inspiron 15 5565 Display Assembly Replacement, Sliding the Display Cable: 手順 11、 2の画像 2
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
ゴール
作成者
1人の作成者と共同作成されました。
Terrence15
メンバー登録日: 12/18/17
79,585 ポイント
441のガイドは作成済み
チーム
RampUP America, Inc. RampUP America, Inc.人のメンバー
Community
43 メンバー
1,985のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 643
