メインコンテンツにスキップ
Redragon Kumara K552 Key Switch Replacement
必要な工具と部品
  1. Redragon Kumara K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 1 Redragon Kumara K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 2 Redragon Kumara K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 3
    • Hook a wire or plastic keycap puller underneath the keycap.
    • Pull the keycap puller straight upwards to remove the keycap.
    • It may help to remove the surrounding keycaps before proceeding to the next step.
  2. Redragon Kumara K552 Key Switch Replacement: 手順 2、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 2、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 2、 3の画像 3
    • Hook the switch puller onto the top and bottom tabs of the switch.
    • Hold the board down with one hand.
    • Use your other hand to squeeze the tabs firmly with the switch puller and pull straight upwards until the switch pops off.
    • If the switch does not pop off, check to make sure the switch tabs are not broken before trying again.
    • Alternatively, you can wedge a spudger underneath the bottom tab of the switch.
    • Use the spudger to squeeze the bottom tab before levering the bottom of the switch upwards.
    • After it partially dislodges, position the spudger under the top tab of the switch.
    • Squeeze and pop the top of the switch off the keyboard.
  3. Redragon Kumara K552 Key Switch Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Inspect the metal pins at the bottom of the switch to see if they have been bent out of shape.
    • A working switch should have straight pins that fit into the circuit board. If the metal pins are bent, straighten them by hand or with pliers/tweezers.
    • This step alone may fix the switch; proceed to Steps 7 and 8 to place and test your switch.
  4. Redragon Kumara K552 Key Switch Replacement: 手順 4、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 4、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 4、 3の画像 3
    • Using a Kailh-style switch opener (which has two wide prongs instead of four), position the switch on top so that the two plastic tabs on the side of the switch are positioned on top of the two prongs underneath.
    • Press very firmly downwards until both tabs unlock.
    • If one tab unlocks and the other tab does not, reset both sides and try again.
    • Alternatively, wedge a spudger underneath the first tab and unlock it slightly.
    • Wedge a spudger underneath the second tab to unlock the top housing.
    • You may have to reset the switch and try again several times.
    • During disassembly, the top portion of the switch may fly off due to the spring underneath.
  5. Redragon Kumara K552 Key Switch Replacement: 手順 5、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 5、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 5、 3の画像 3
    • The four parts of a switch are the stem, top housing, spring, and bottom housing. Make sure you have all four parts before proceeding.
    • Check the metal leaf inside the bottom housing to make sure there is no rust or bends.
    • You may find some lubricant clinging onto the leaf, which can be wiped off using a cotton swab.
  6. Redragon Kumara K552 Key Switch Replacement: 手順 6、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 6、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 6、 3の画像 3
    • To reassemble the switch, place the spring within the bottom housing on top of the circular post inside.
    • Place the stem inside the top housing so the stem legs face away from the rectangular opening in the top housing.
    • Assemble the switch so the rectangular opening in the top and bottom housing match up.
    • Be careful not to lose any of the four parts of the switch, especially the spring.
  7. Redragon Kumara K552 Key Switch Replacement: 手順 7、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 7、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 7、 3の画像 3
    • Reinsert the switch into the keyboard by placing the switch where the rectangular opening is facing upwards and the Redragon logo is facing downwards in relation to the surrounding switches.
    • Firmly push downwards on the housing (not the stem) until it clicks into place.
  8. Redragon Kumara K552 Key Switch Replacement: 手順 8、 2の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 8、 2の画像 2
    • Test your keyboard afterwards using a keyboard testing website such as Keyboard Tester to make sure your switch works.
    • If your switch does not work, either your fix did not work and you will need to completely replace the switch or you bent the pins when reinserting the switch into the board. Refer to Steps 2 and 3 for switch removal and bent pins respectively.
  9. Redragon Kumara K552 Key Switch Replacement: 手順 9、 3の画像 1 Redragon Kumara K552 Key Switch Replacement: 手順 9、 3の画像 2 Redragon Kumara K552 Key Switch Replacement: 手順 9、 3の画像 3
    • If you are replacing the switches that the keyboard comes with for aftermarket switches, be aware that not all aftermarket switches will fit into this keyboard. Since this keyboard uses Outemu hot-swap sockets, it will only accept switches with smaller pins.
    • In the photos, the switches on the left are compatible with this keyboard, while the switches on the right are not compatible with the keyboard due to their slightly thicker pins.
終わりに
You can now use your keyboard as usual.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Matt Chan
メンバー登録日: 01/17/22
211 ポイント
1ガイドが承認済み
チーム
York University, Team S-3, Woodhouse Winter 2022 York University, Team S-3, Woodhouse Winter 2022人のメンバー
YORK-WOODHOUSE-W22SSG3
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 113
過去 30 日: 432
今までの合計 13,962
