メインコンテンツにスキップ
Redragon K552 Key Switch Replacement
必要な工具と部品
  1. Redragon K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 1 Redragon K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 2 Redragon K552 Key Switch Replacement, Key Switch: 手順 1、 3の画像 3
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: 手順 2、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 2、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 2、 3の画像 3
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: 手順 3、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 3、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 3、 3の画像 3
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: 手順 4、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 4、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 4、 3の画像 3
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: 手順 5、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 5、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 5、 3の画像 3
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: 手順 6、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 6、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 6、 3の画像 3
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: 手順 7、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 7、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 7、 3の画像 3
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: 手順 8、 3の画像 1 Redragon K552 Key Switch Replacement: 手順 8、 3の画像 2 Redragon K552 Key Switch Replacement: 手順 8、 3の画像 3
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Lyxander Blanco
メンバー登録日: 03/19/22
187 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 6-2, Briggs Spring 2022 CSU Los Angeles, Team 6-2, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S6G2
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 130
今までの合計 6,547
