メインコンテンツにスキップ
RedOctane X-Plorer Whammy Bar Replacement
必要な工具と部品
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 手順 1、 2の画像 1 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: 手順 1、 2の画像 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: 手順 2、 3の画像 1 RedOctane X-Plorer Whammy Bar Replacement: 手順 2、 3の画像 2 RedOctane X-Plorer Whammy Bar Replacement: 手順 2、 3の画像 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: 手順 3、 3の画像 1 RedOctane X-Plorer Whammy Bar Replacement: 手順 3、 3の画像 2 RedOctane X-Plorer Whammy Bar Replacement: 手順 3、 3の画像 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 手順 4、 3の画像 1 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 手順 4、 3の画像 2 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: 手順 4、 3の画像 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: 手順 5、 1の画像 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: 手順 6、 2の画像 1 RedOctane X-Plorer Whammy Bar Replacement: 手順 6、 2の画像 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: 手順 7、 1の画像 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: 手順 8、 1の画像 1
    • Using two hands, remove the spring from the plastic tabs.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
[deleted]
メンバー登録日: 04/18/18
175 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 95
今までの合計 3,524
