メインコンテンツにスキップ
RedOctane X-Plorer Rubber Button Strip Replacement
必要な工具と部品
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 手順 1、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: 手順 1、 2の画像 2
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 2、 1の画像 1
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 3、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement: 手順 3、 2の画像 2
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 4、 1の画像 1
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 5、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement: 手順 5、 2の画像 2
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    Flathead 1.5 mm Screwdriver
    $5.49
    購入する
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 7、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement: 手順 7、 2の画像 2
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 8、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement: 手順 8、 2の画像 2
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: 手順 9、 2の画像 1 RedOctane X-Plorer Rubber Button Strip Replacement: 手順 9、 2の画像 2
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
終わりに
作成者
3人の作成者と共同で作成されました。
Stephen Haning
メンバー登録日: 09/30/21
169 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-1, Boettger Spring 2022 University of North Texas, Team 1-1, Boettger Spring 2022人のメンバー
UNT-BOETTGER-S22S1G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 233
