はじめに
If the motherboard becomes damaged, all other electronics must be removed first before you can access it. This guide will show you the steps necessary to access the motherboard.
必要な工具と部品
Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
Gently lift up on the auxiliary port to remove it from the case.
Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
Lift the RJ-14 connector to remove it from the case.
Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
Lift up on the strum bar sensor board to remove it from the case.
Remove the two 7mm Phillips #0 screws.
Using your fingers, remove the black wire retainer.
Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
Lift the motherboard to remove it from the case.
ある他の人がこのガイドを完成しました。
