メインコンテンツにスキップ
RedOctane X-Plorer Front Case Replacement
必要な工具と部品
  1. RedOctane X-Plorer Front Case Replacement, Rear Case: 手順 1、 2の画像 1 RedOctane X-Plorer Front Case Replacement, Rear Case: 手順 1、 2の画像 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Front Case Replacement: 手順 2、 3の画像 1 RedOctane X-Plorer Front Case Replacement: 手順 2、 3の画像 2 RedOctane X-Plorer Front Case Replacement: 手順 2、 3の画像 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Front Case Replacement: 手順 3、 3の画像 1 RedOctane X-Plorer Front Case Replacement: 手順 3、 3の画像 2 RedOctane X-Plorer Front Case Replacement: 手順 3、 3の画像 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 手順 4、 3の画像 1 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 手順 4、 3の画像 2 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: 手順 4、 3の画像 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 手順 5、 3の画像 1 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 手順 5、 3の画像 2 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: 手順 5、 3の画像 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Front Case Replacement, Keys: 手順 6、 3の画像 1 RedOctane X-Plorer Front Case Replacement, Keys: 手順 6、 3の画像 2 RedOctane X-Plorer Front Case Replacement, Keys: 手順 6、 3の画像 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Front Case Replacement: 手順 7、 1の画像 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Front Case Replacement: 手順 8、 2の画像 1 RedOctane X-Plorer Front Case Replacement: 手順 8、 2の画像 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 手順 9、 3の画像 1 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 手順 9、 3の画像 2 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: 手順 9、 3の画像 3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 手順 10、 3の画像 1 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 手順 10、 3の画像 2 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: 手順 10、 3の画像 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Front Case Replacement: 手順 11、 2の画像 1 RedOctane X-Plorer Front Case Replacement: 手順 11、 2の画像 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Front Case Replacement: 手順 12、 1の画像 1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Front Case Replacement, Motherboard: 手順 13、 3の画像 1 RedOctane X-Plorer Front Case Replacement, Motherboard: 手順 13、 3の画像 2 RedOctane X-Plorer Front Case Replacement, Motherboard: 手順 13、 3の画像 3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
  14. RedOctane X-Plorer Front Case Replacement, Front Case: 手順 14、 2の画像 1 RedOctane X-Plorer Front Case Replacement, Front Case: 手順 14、 2の画像 2
    • Remove the four 12mm Phillips #1 that connect the body to the neck using a screwdriver.
  15. RedOctane X-Plorer Front Case Replacement: 手順 15、 1の画像 1
    • Remove the neck panel from the front body panel.
終わりに
作成者
4人の作成者と共同で作成されました。
Riley
メンバー登録日: 04/18/18
649 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S17-G1, Livingston Spring 2018 Cal Poly, Team S17-G1, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S17G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 752
