はじめに
If your RedMax Brush Cutter BCZ3050S is not operating properly or sputtering, it might be time to replace your spark plug. A new spark plug ensures that your brush cutter is operating smoothly.
Machines in today’s age require multiple parts for them to function properly. Luckily for us, these brush cutters require far less parts than a car. The brush cutter and cars do have one important part in common. The part that they have in common is the spark plug. The spark plug is the ignition source for the brush cutter so it can be up and running to perform lawn activities.
Unlike vehicles, the brush cutter spark plugs are easily accessible to find and change. This is the guide to help you replace your spark plug so that you can be back to work in no time.
Before attempting to replace your spark plug with this guide, make sure to have the brush cutter cool off completely or cool off enough so that the machine is not warm to the touch.
必要な工具と部品
Look for the black plastic cover with ridges on the top of the brush cutter. Your fingers should be enough to pull the plastic off, but you may use a flat head screwdriver instead.
ある他の人がこのガイドを完成しました。
