メインコンテンツにスキップ
Realspace EC600 Office Chair Lift Cylinder Replacement
必要な工具と部品
  1. Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: 手順 1、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement, Lift Cylinder: 手順 1、 2の画像 2
    • Position the chair so that you have access to the underside of its base.
    • Some of the parts will be coated in oil and can create a mess in your workspace.
  2. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 2、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 2、 2の画像 2
    • Remove the spring retaining clip by lifting with the flathead screwdriver and sliding it off with your thumb.
    • Remove the washer that was underneath the clip.
  3. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 3、 1の画像 1
    • Lift the base off of the lift cylinder.
    • The rubber bumper, washers, and bearings may fall off during this step.
  4. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 4、 1の画像 1
    • Remove the rubber bumper, washers, and bearings.
  5. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 5、 1の画像 1
    • Remove the lift cylinder cover.
  6. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 6、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 6、 2の画像 2
    • Spray WD-40 around the base of the lift cylinder.
    • Loosen the cylinder off the chair by rotating it with the pipe wrench.
    • If you are having trouble rotating the the cylinder off, then wrap painter's tape around where you are rotating the cylinder.
  7. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 7、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 7、 2の画像 2
    • Remove the old lift cylinder.
    • Press the new cylinder into the chair.
    • The ends of the cylinder will have oil on them so they may make a mess.
  8. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 8、 1の画像 1
    • Push the lift cylinder cover onto the new cylinder.
  9. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 9、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 9、 2の画像 2
    • Push the rubber bumper, washers, and bearings onto the lift cylinder.
    • The order should be from the chair to the rubber bumper, washer, bearings, and then the other washer.
  10. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 10、 1の画像 1
    • Set the base over the lift cylinder and press it onto the cylinder.
  11. Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 11、 2の画像 1 Realspace EC600 Office Chair Lift Cylinder Replacement: 手順 11、 2の画像 2
    • Place the washer at the end of the cylinder.
    • Slip the spring retaining clip onto the end of the cylinder.
終わりに
Finally, flip the chair back over and press down on the seat of the chair to make sure the cylinder is completely pressed in.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Patrick Kay
メンバー登録日: 09/16/20
274 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S4-G20, Kim Fall 2020 University of Memphis, Team S4-G20, Kim Fall 2020人のメンバー
UM-KIM-F20S4G20
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 37
過去 30 日: 113
今までの合計 2,264
