メインコンテンツにスキップ
Realigning 12-Inch Bionaire Fan Metal Coil
必要な工具と部品
  1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: 手順 1、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: 手順 1、 2の画像 2
    • Unlock all of the tabs holding the fan cage together.
    • Carefully pull off the cage.
  2. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 2、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 2、 2の画像 2
    • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
    • Blade may be sharp so watch out!
    • Cautiously remove the blade from the hinge.
    • Put the screws in a cup so you don't lose them!
  3. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 3、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 3、 2の画像 2
    • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
    • Pull off the back cage from the engine holder.
  4. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 4、 1の画像 1
    • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
  5. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 5、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 5、 2の画像 2
    • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
  6. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 6、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 6、 2の画像 2
    • Pull of the black knob by rotating the knob counter-clockwise.
    • Pull down the black cover all the way.
    • The coil may pop out after removing the cover.
  7. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 7、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 7、 2の画像 2
    • Take out the gold metal spring.
    • Realign the metal coil into designated space.
    • Push the coil in with some force so it rests perfectly in the space.
    • To make placing the coil back in more easier, use the screwdriver!
  8. Realigning 12-Inch Bionaire Fan Metal Coil: 手順 8、 2の画像 1 Realigning 12-Inch Bionaire Fan Metal Coil: 手順 8、 2の画像 2
    • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
    • This can be a frustrating step. Be patient!
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hemish Patel
メンバー登録日: 09/29/15
231 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G3
4 メンバー
4のガイドは作成済み
1件のガイドコメント
I have a fan It hum I have to spin the blade for it to start spin
Chris - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 12
今までの合計 3,955
